In HyperLife v2026, for frequency-domain sine sweep fatigue using FRF results (Vibration → Frequency Domain, Sine), how is “Number of Sweeps” defined internally?
Specifically:
- Does 1 sweep correspond to a single-direction sweep (Start → End frequency), or
- Does 1 sweep correspond to a full cycle (Start → End → Start)?
In FRF Analysis I have entered frequency load from 7Hz to 200Hz, with a frequency increment of 1 Hz.
This clarification is required to correctly model test standards (e.g., AIS-156 vibration: 7–200–7 Hz, 15 min per cycle, 12 cycles) without over- or under-counting fatigue damage.
