🎉Community Raffle - Win $25
Join and Win
SimLab crashes when trying to use the interior angle cleanup?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello.
Everytime I atempt to use the 'clean up' function for the interior angle on tetra elements Simlab ends up crashing. The clean up works fine when used on 2D-tri elements but crashes when used on tetra elements. Why does this happen?
Kind regards
Sanin
1 - 9 of 91
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Could you tell us which version of simlab you are using?
    Regards
    Rahul R
    Altair Employee
    OP
    It is 13.2
    Hi,
    Which option of cleanup you are using?automatic or manual.
    Could you take screenshot of parameters set for cleanup?
    If model is simple please share us through file transfer.
    Regards
    Rahul R
    Altair Employee
    OP
    Hi,
    Basically I go under mesh and then quality check.  I then press compute to see how many elements fail the given criterias. I then use the 'clean up' operation in quality check on each criteria that has elements that failed. This works for each criteria except for interior angle for tetra elements. If the cleanup is atempted, the window 'This program has stoped working' appears and SimLab crashes.
    I used 13 degrees as minimum angle and 140 for maximum.
    I cannot screenshot the particular detail I have been meshing but it is not a simple geometry. I could try to reproduce the scenario on a different detail if you still think that a screenshot would be usefull.
    Kind regards
    Sanin
    Hi,
    Thanks for sharing information.
    Till now nobody have reported such issue in simlab latest version of 13.2 We request you to check same in some other model.would be nice if you share the model.
    Regards
    Rahul R
    Altair Employee
    OP
    I have made a model for you which replicates the circumstances. How do I send it to you?
    Regards
    Sanin
    Hi,
    Please use below link to upload file.
    https://ftam1.altair.com/filedrop/rahul.rajan@altair.com
    Regards
    Rahul R
    Altair Employee
    OP
    I have sent it. Please notify me of how it goes.
    Thank you.
    Sanin
    Altair Employee
    OP
    Hello again,
    I was hoping to get some information about this. Have u managed to generate the same error? Any idea of whats causing it?
    Thank you
    Sanin
