🎉Community Raffle - Win $25
Join and Win
Error FILE*.rst NOT FOUND
Hi,
Please help me for the error FILE*.rst NOT FOUND
Thanks for advance
Here is error:
 ** ERROR: FILE frot_0000_0001.rst NOT FOUND
     ERROR TERMINATION
application called MPI_Abort(MPI_COMM_WORLD, 2) - process 0
[8:woinic-0-3.local] unexpected disconnect completion event from [0:woinic-0-4.local]
Assertion failed in file ../../dapl_conn_rc.c at line 1179: 0
internal ABORT - process 8
[4:woinic-0-4.local] unexpected disconnect completion event from [8:woinic-0-3.local]
internal ABORT - process 4
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 11018 RUNNING AT woinic-0-4
=   EXIT CODE: 2
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
1 - 9 of 91
    Hilongct,
    Are you running the simulation on a cluster?
    could you please let us know the operating system and details.
    Hi Prakash,
    Yes, the calculation is runned on the cluster.
    OS : linux redhat-6
    Gestionnaire de batch : Torque/Maui
    and here is the batch file:
    #!/bin/bash
    #PBS -N 2D_test
    #PBS -q default
    #PBS -j oe
    #PBS -l nodes=3:ppn=12
    #PBS -l walltime=12:00:00
    What is the MPI installed?
    can you share the details of MPI and version?
    Hi,
    It is the Intel MPI, and here is the MPI info:
    mpirun -info
    HYDRA build details:
        Version:                                 4.1 Update 3
        Release Date:                            20140124
        Process Manager:                         pmi
        Bootstrap servers available:             ssh rsh pdsh fork slurm srun ll llspawn.stdio lsf blaunch sge qrsh persist jmi service
        Resource management kernels available:   slurm srun ll llspawn.stdio lsf blaunch sge qrsh pbs
        Checkpointing libraries available:        blcr
        Demux engines available:                  poll select
    Thanks,
    I will check and get back to you ASAP!
    HI,
    Two questions:
    a.)    Is it a single host job?
    b.)    Is the stacksize of the machine(s) set to unlimited?
    Hi Mr Prakash,
    For your question:
    a) It is not a 'single host job', because I started my job with '#PBS -l nodes=2:ppn=8'. This job revolved on the nodes at  12 cores and another jobs revolved in the same time on these nodes.
    b.) Stacksize is not set on 'unlimited'.
    That is the information from the technician in our calcul centre.
    Hi LongCt
    can you run the simulation on a single node?
    Hi Parakash,
    Today, I tried to run the simulation on a single node in two ways:
    1) On my destop computer:
    {C:/Program Files/Altair/12.0/hwsolvers/common/tcl/tcl8.5.9/win64/bin/tclsh85t.exe} {C:/Program Files/Altair/12.0/hwsolvers/scripts/hwsolver.tcl} {J:/Bulk_fibres/Lan 1/1800x2400/1800x2400_0000.rad} -screen -nt 8 -dir
    Job load: 1
    setRdEnv windows
    Error output from the solver:
    forrtl: There is not enough space on the disk.
    forrtl: severe (38): error during write, unit 19, file C:\Users\Long2014\AppData\Local\Temp\FOR9749.tmp
    Image              PC                Routine            Line        Source
    s_12.0.210_win64.  0000000140BB82EF  Unknown               Unknown  Unknown
    s_12.0.210_win64.  0000000140B9FA6B  Unknown               Unknown  Unknown
    kernel32.dll       0000000076C359ED  Unknown               Unknown  Unknown
    ntdll.dll          0000000076E6C541  Unknown               Unknown  Unknown
    Restart file 1800x2400_0000_0001.rst was not created.
    radioss:: Solver run finished after 2 minutes.
    2) On the cluster (calculation center):
    The error is the same in the case of running on several nodes:
      .. INTERFACES
    Restart file frot_0000_0001.rst was not created.
    radioss:: Solver run finished after 3 minutes.
