🎉Community Raffle - Win $25
Join and Win
What MAT LAW should be used for plastic in Radioss?
User: "James Lewis"
Altair Community Member
Updated by James Lewis
Hi guys,
I want to simulate a drop test with my plastic part.
And I don't know what should mat law should I used for it.
I have stress strain curve csv file like below.
Thank you!
1 - 4 of 41
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    Hi, LAW36 (PLAS_TAB) should be ok for this: It needs True Plastic Stress vs Strain (ratio) as input
    I've assumed your data above is engineering stress vs strain(%)?
    Converting to True Plastic Stress vs Strain for LAW36:
    Offset stress/strain to 0,0 and divide strain by 100
    True Strain: Take Natural Log of 1 + Eng Strain
    True Stress: Eng Stress * Exponent (Eng Strain)
    Estimate Elastic Modulus (E)
    Plastic Strain = True Strain - True Stress/E
    As Material: also attached as file (I have set density as 5g/cm^3 and poissons ratio as 0.3), you may modify those if you have better data
    Hope this helps
    User: "James Lewis"
    OP
    Hope this helps
    Hi Paul,
    Thank you for your great explain.
    I've applied your method and successfully created data for material.
    But can I have a more question that, do you know how to convert material from .csv file using tcl scripts.
    Best regards,
    James
    User: "PaulAltair"
    Altair Employee
    Hi Paul,
    Best regards,
    James
    There is a specific tool 'Altair Material Modeler' that is an interface for Compose,
    Material Modeler
    it does everything for you... but it is not 'free' (draws license units)
    User: "James Lewis"
    OP
    Material Modeler
    That really helpful, thank you!
