Topology optimization. minimizing compliance for specified volume fraction
In topology optimization when minimizing compliance for specified volume fraction, the maximum deflection of optimized structure is less than the maximum deflection of original structure?
based on this formula
For constant F when compliance is minimized U( deflection) should be minimized and vice versa. but in this formula volume fraction is not considered.
I don't understand the concept of minimum compliance. The compliance of the optimized structure which is lighter than the original structure (since some material is removed from it) is even less than the original structure??!!
1 - 8 of
81
Hi,
the equation can be re-written as C= F[K]-1F where for a constant force only Stiffness can be changed. in which case, Volume fraction is an other entity of response.
Again, A final optimization can then fine tune the design at the boundaries and hence allow local stiffening for reducing stresses.
