Warning ID 760
Hello,
I am trying to simulate a deep drawing process of a thermobimetal plate with HyperCrash. The current model is very crude, but will be improved once this Problem is solved.
When trying to solve my model with RADIOSS I Encounter the following error:
** RADIOSS STARTER 2017.2.1 **
** Non-linear Finite Element Analysis Software **
** from Altair Engineering, Inc. **
** Windows 64 bits, Intel compiler **
** Build tag: 0876086_123352072.1_1020_0049245_10 **
** COPYRIGHT (C) 1986-2017 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
.. BLOCK FREE FORMAT
.. STARTER RUNNING ON 1 THREAD
.. CONTROL VARIABLES
.. UNITS SYSTEM
.. FUNCTIONS & TABLES
.. MATERIALS
WARNING ID : 765
** WARNING IN MATERIAL LAW
WARNING ID : 765
.. NODES
.. PROPERTIES
.. 3D SOLID ELEMENTS
.. 3D SHELL ELEMENTS
.. 3D TRIANGULAR SHELL ELEMENTS
.. SUBSETS
.. ELEMENT GROUPS
.. PART GROUPS
.. SURFACES
.. NODE GROUP
.. BOUNDARY CONDITIONS
.. IMPOSED VELOCITIES
.. AMS INITIALIZATION
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. INTERFACES
.. INTERFACE BUFFER INITIALIZATION
.. RIGID BODIES
.. RETURNS TO DOMAIN DECOMPOSITION FOR OPTIMIZATION
.. ELEMENT GROUPS
.. INTERFACES
.. RIGID BODIES
.. ELEMENT BUFFER INITIALIZATION
** ERROR TRAPPED : REPORT TO LISTING FILE
ERROR ID : 760
==== End of solver screen output ====
==== Job completed ====
I have attached the .rad file I exported from HyperCrash.
I would appreciate any help. Thank you in advance.
