LINEAR STATIC
Hello everyone
Good morning
i am doinig linear static analysis in optistruct. At first i have run it with first order tetra mesh then i have run it again with second order tetra mesh.i have get both result and both are different.can anyone suggest me, is first order tetra mesh give accurate value of stress(result) or second order tetra mesh.
regard
Noor Alam
hi Prakash
i am simulating it without contact.
1.At first order tetra result is stress is 291.3 MPa. here (Hyperview averaging is none), but when i am set the averaging method advance the stress is suddenly reduced 204.5 MPa.
2.At second order tetra mesh the stress is 335.1 MPa.Here stress is same at averaging method None/Advanced in hyperview.
my problem is involved with bending.
could you show result pics and load pics?
you have more grids in your model now and it can change your loading.
Good point, is the amount of load same in both cases?
Hi @NOOR ALAM ANSARI
How big is the difference?
Does your problem involve contacts?
2nd order is more accurate over 1st order, but not in all cases. For example, 1st order performs better when you have contacts.
If your problem involves bending, incompressibility 2nd order is accurate.
