Hi experts,
I want to do a structural analysis of the screw shaft. I tried to do small sliding, finite sliding, and continuous sliding, but it could not still converge.
Can you help me fix this bug?
Thanks
Hi BrianYou have some severe penetration in your model which will make your model hard to converge. Overlap can be modelled and need to resolved prior to rotation.
Here is and interference fit model:
OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders (altair.com)
And here is a case of large sliding
OS-E: 0160 Nonlinear Static Analysis of Snap Fit Assembly Using Continuous Sliding (altair.com)Be careful with meshing, it is good to coarsen the mesh out to reduce model size!
For initial set-up, you can also consider to just model 1-2 threads!/Johan
Hi BrianYou have some severe penetration in your model which will make your model hard to converge. Overlap can be modelled and need to resolved prior to rotation. Here is and interference fit model: OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders (altair.com) And here is a case of large sliding OS-E: 0160 Nonlinear Static Analysis of Snap Fit Assembly Using Continuous Sliding (altair.com)Be careful with meshing, it is good to coarsen the mesh out to reduce model size! For initial set-up, you can also consider to just model 1-2 threads!/Johan
Hi @Johan Dahlberg,
How to reduce the penetration because the model has many nodes so we cannot use translate or move nodes? Maybe I can use scale for the screw shaft or not?
Hi @Johan Dahlberg, How to reduce the penetration because the model has many nodes so we cannot use translate or move nodes? Maybe I can use scale for the screw shaft or not? Thanks
Hi Brianyes downscaling and then apply radial displacment of bolt could be one option.I would have started with a interference fit (overlap) subcase to resolve the initial state.
Anyway, you need to define two subacases:
subcase 1, Interference fit
subcase 2, continuation from first subcase, and then apply rotation only/Johan
I tried to do this but the results seem not good.
Can you check it for me?
Please find the attachment to see my model
