Could not initialize HTML5 browser! See log for details - Mac Sequoia 15.5
Description: Can't see visualizations. Receive this error.
Product/Topic Name : Altair Studio 2025.1.0
Please see attached log. I searched for solutions and enabled, "HTML5 Safe mode" but I can't find an option for "Show legacy simple charts".
INFO: Global Search GUI provider added for category marketplace.
May 29, 2025 12:32:55 PM com.rapidminer.extension.cta.tools.CTAVisualizationRegistry getVisualization
WARNING: Failed to display a CTA
java.lang.UnsupportedOperationException
at com.rapidminer.gui.renderer.html.BasicHTMLRenderer.registerJavascriptCallback(BasicHTMLRenderer.java:63)
at com.rapidminer.extension.cta.gui.BrowserPopup.<init>(BrowserPopup.java:306)
at com.rapidminer.extension.cta.gui.BrowserPopup.<init>(BrowserPopup.java:276)
at com.rapidminer.extension.cta.tools.CTAVisualizationRegistry.lambda$registerVisualization$0(CTAVisualizationRegistry.java:60)
at com.rapidminer.extension.cta.tools.CTAVisualizationRegistry.getVisualization(CTAVisualizationRegistry.java:76)
at com.rapidminer.extension.cta.tools.CallToActionScheduler.checkRules(CallToActionScheduler.java:272)
at com.rapidminer.extension.cta.tools.CallToActionScheduler.lambda$init$0(CallToActionScheduler.java:121)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
May 29, 2025 12:32:55 PM com.rapidminer.extension.cta.tools.CallToActionScheduler checkRules
WARNING: No visualization available for CTA rule 'RET-EXT-TEXT-02C_query_fes'.
May 29, 2025 12:34:39 PM com.rapidminer.extension.browser.BrowserFactory init
SEVERE: Failed to initialize the Browser, HTML5 components might not be available!
com.teamdev.jxbrowser.engine.ChromiumBinariesDeliveryException: Failed to extract Chromium binaries into /Users/naveen.athuluru/.AltairRapidMiner/AI Studio/2025.1.0/internal cache/browser8.3.0-OSX
at com.teamdev.jxbrowser.internal.OfficialDelivery.deliverTo(OfficialDelivery.java:56)
at com.teamdev.jxbrowser.engine.ChromiumBinaries.lambda$deliverTo$0(ChromiumBinaries.java:146)
at com.teamdev.jxbrowser.engine.ChromiumBinaries.trySynchronized(ChromiumBinaries.java:176)
at com.teamdev.jxbrowser.engine.ChromiumBinaries.deliverTo(ChromiumBinaries.java:141)
at com.teamdev.jxbrowser.engine.ChromiumBinaries.deliverTo(ChromiumBinaries.java:100)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:147)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:163)
at com.rapidminer.extension.browser.BrowserFactory.createEngine(BrowserFactory.java:408)
at com.rapidminer.extension.browser.BrowserFactory.init(BrowserFactory.java:165)
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:272)
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:236)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI.createChartSceneJxBrowser(HTML5HighChartsChartGUI.java:416)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1.doInBackground(HTML5HighChartsChartGUI.java:159)
at com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1.doInBackground(HTML5HighChartsChartGUI.java:155)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.io.FileNotFoundException: chromium-mac-arm.7z
at com.teamdev.jxbrowser.internal.OfficialDelivery.deliverTo(OfficialDelivery.java:54)
... 19 more
May 29, 2025 12:34:39 PM com.rapidminer.extension.html5charts.gui.chart.implementations.html5.HTML5HighChartsChartGUI$1 done
SEVERE: Failed to create HTML5 browser!
java.lang.NullPointerException: Cannot invoke "com.teamdev.jxbrowser.engine.Engine.newBrowser()" because "com.rapidminer.extension.browser.BrowserFactory.ENGINE_HARDWARE_ACCELERATED" is null
at com.rapidminer.extension.browser.BrowserFactory.createBrowser(BrowserFactory.java:298)
Hi Naveen,
It will be a day or so before I can get to a Mac on which to try this, although it does not seem to be a new issue since I found the following post, where the same error occurred in 2023:
Out of curiosity, can you tell me if the following directory exists on your system, and if it does, can you test to see if you can create a file there? /Users/<username>/.AltairRapidMiner/AI Studio/2025.1.0/internal cache/browser8.3.0-OSX
I see - is there any folder directly under the
folder which begins with the string "browser"?
You're quite welcome.
At this point I would need to take a look at your system and to do that, you will need to open a Support ticket.
Could you please visit https://support.altair.com/ , create a Support ticket and please mention that you'd like Nicholas Linsky to work on it.
I have the same concern, @Nicholas_21406 could you also lend me a hand on how to address this concern. thanks
I would also ask you to open a support ticket at https://community.altair.com/home/leaving?allowTrusted=1&target=https%3A%2F%2Fsupport.altair.com%2F so that we can take a look at your system on a screenshare.
Thanks!
sir @Nicholas_21406 my educational account can't open a support ticket. how can we proceed with this? hoping for positive progress on this concern. thank you in advance.
"Case Management Availability
Technical Support via our case management system is not enabled on your account."
Hi @Makssssssssssss ,
Sorry to hear you do not have access to open a Support ticket.
If https://community.altair.com/profile/481003/NaveenA opens a Support case, then I will meet with them to try to diagnose what is the issue there, which might give me more ideas I can post here.
Hi Nicholas, I am also facing the same issue. However, I could see the folder /Users/<username>/.AltairRapidMiner/AI Studio/2025.1.0/internal cache/browser8.3.0-OSX, as well as could move a document created there. What next? How to fix the browser issue to open the visualisation on my MacBook with macOS Sequoia 15.5.
Hi @Vani_Vasudevan ,
I will be meeting with @NaveenA on Friday and hope to have more information at that point, which I will post back to here.
I would also be happy to look at your system, which would require you to open a Support ticket at https://support.altair.com/
@NaveenA, @Makssssssssssss , I have met with @Vani_Vasudevan and collected the information I needed about this issue.
It appears there is indeed a defect in the 2025.1.0 AI Studio Macintosh edition.
I am going to be filing the defect shortly and will let you know what the developers say, but as an interim test and workaround, could you please download the 2025.0.1 version of AI Studio and install it - you do not need to uninstall 2025.1.0.
To find this previous version on the Marketplace, just select the dropdown for the AI Studio version number, also select the "Show previous versions" checkbox, and then download the older installer.
Please let me know the results of your test.
Hi @Vani_Vasudevan I had reproduced the error on my own Mac and filed a defect with development.
They were not able to reproduce and pointed out that for the version 2025.1, there are two different installers for Mac and we may have chosen the wrong one.
When I get home I will be trying out the other installer on my Mac Book and will let you know the results. If you are able to try this before then, please let me know what happens.
Thanks!
Hi there, I am on Sequoia 15.6.1 and having this issue today. Was a fix ever discovered? I see the option to try 2025.01 and also that there may have been a faulty installer. I do have access to the file path in previous comments, but am unsure what to do at that point.
I would appreciate any advice to bypass this error message. Thank you!
Hi @eabrandon ,
There are two different installers available - I'm not 100% clear on which one if for which type of processor but have found that one of them works properly on my Mac (Book Air) and the other does not.
So you may want to try each installer and see if one of them works better for you.
Note also that AI Studio 2026.0.1 is now available.
Attached are log files. Thank you for assisting.
