How can I apply multiple constraints or loads in a subcase?
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
OptiStruct can only accept one SPC and one LOAD component in a subcase, by default. In other words, multiple load collectors with e.g. different SPC's can't be referenced in the load step panel. There are two ways to apply multiple constraints and loads in a subcase.
1. Put multiple loads in one load collector, and include that one load collector in the subcase. The same method can be used in the case of multiple constraints.
2. Create load collectors for each and every load and constraint set. When you want to apply multiple loads in a subcase, a new load collector needs to be created with the LOAD card (=CardImage=Load). Then, individual load collectors can be combined using the LOAD card. The LOAD card also enables you to associate an independent weighting factor to an individual load collector. In the case of applying multiple constraints, create a new load collector with the SPCADD card (=CardImage), and follow the same procedure as in the multiple load case. Once the combined load collectors are created, they can be applied in a subcase.
