Altair RISE
Nominate Yourself Now!
Problem with hm_findconnectedpatches
User: "Deleus"
Altair Community Member
I'm currently using hm_findconnectedpatches to find the number of patches of a collection of elements along their respective extensions.
I'm encountering a strange behaviour where TRIA elements are not considered in the selection.
In other words, by visualizing those patches, you can clearly see TRIA elements have not been added to the selection.
Any idea?
Daniele
1 - 1 of 11
    Hi @Deleus,
    This issue has been observed and it has been already solved by our development team. It will be available in HyperMesh 2026.0.
    For now if you want to use the command's functionality please use the following:
    import hm
    import hm.entities as ent
    import hw
    model=hm.Model()
    # Workaround using evalTcl
    hw.evalTcl("*createmark elems 1")
    result=hw.evalTcl("hm_findconnectedpatches elems 1")
    result = result.replace("{","")
    result = result.replace("}","")
    idlist=result.split(" ")
    # Create entity list
    elem_list = [ent.Element(model,int(id)) for id in idlist]
    If you have any further query regarding this please do not hesitate to continue the discussion!
    Thank you!
    User: "Deleus"
    OP
    Thanks for the fast and precise answer Dimitrios! How does this work around the issue?
    Also, I wrote my own fast version of hm_findconnectedpatches while waiting, I'm eager to test it against your version.
