🎉Community Raffle - Win $25
Join and Win
How to visualize multiple reflections with ray paths in POSTFEKO with RL-GO and a plane wave source
User: "Florindo_96"
Altair Community Member
Hi everyone,
I'm working with FEKO using the RL-GO (Ray Launching Geometrical Optics) solver and a plane wave source (RCS problem). I would like to visualize the multiple reflections (ray paths) in POSTFEKO, but it seems that I can only see the first ray in the simulation.
Is there a specific setting or output request I need to activate during the simulation in CADFEKO or a feature in POSTFEKO that allows me to see all the traced rays, including their multiple reflections?
Thanks in advance for your help!
1 - 2 of 21
    User: "mvogel"
    Altair Employee
    Accepted Answer
    You probably already had checked the "Export Ray Data" option in CADFEKO, under Solver Settings —> High Frequency Tab —> RL-GO settings.
    In POSTFEKO, with Ray Type: All and interactions up to 3, it should work, as shown below
    The attached zip file contains a version-2025 example. If you don't have version 2025, then don't worry about the example project and just try these settings in your own model.
    User: "Florindo_96"
    OP
    Thank you very mouch for your clear answer !!!
