Tutorials
User: "Johnson"
Altair Community Member
Updated by Johnson
Hello,
Please, can someone help me with the link to find the list of all the Tutorials available for EDEM?
Thank you
1 - 5 of 51
    User: "GTT Adam"
    Altair Employee
    Hi @Johnson,
    Tutorials for EDEM can be found directory in the Help Documentation
    Additional training can be found online through our eLearning resources.
    Hope this helps!
    Adam Reid
    User: "Johnson"
    OP
    Updated by Johnson
    Thank you. Adam.
    But I could not access the Help documentation. Below is the message popping up, and when I continued to the external site, it was not working. But the e-learning link is working fine.
    User: "GTT Adam"
    Altair Employee
    Hi @Johnson,
    From an open session of EDEM, simply press F1 to access the Help or use the Help button in the ribbon:
    Hope this helps!
    Adam Reid
    User: "Johnson"
    OP
    Thank you, Adam
    User: "GTT Adam"
    Altair Employee
    Hi @Johnson,
    Not a problem.
    To help other Users find this solution quickly, please make sure to mark one of the above responses as Correct.
    Thanks,
    Adam Reid
