🎉Community Raffle - Win $25
Join and Win
Automatic Curves Export after simulation
User: "Thomas_"
Altair Community Member
Updated by Thomas_
Hi,
I'm currently running simulations on MotionView 2022.1. I have multiple outputs i want to export in .CSV format.
To do that, i select my curve in the plot window and select : export curves.
I do that one by one for each output i need to export.
I there a solution to "automatically" export selection of outputs in a .CSV format after running a simulation ?
Thanks for your help.
Regards.
Thomas
1 - 4 of 41
    User: "GTT Adam"
    Altair Employee
    Updated by GTT Adam
    Hi @Thomas_Bécue,
    Yes, this can be accomplished through scripting or, in new versions of MotionView, the use of MotionSolve Jupyter Notebook (recommended).
    The scripting method would require the solving and post-processing to be run by either a batch file, Python script, Compose script, etc.
    If using batch, you can solve a MDL using the following syntax:
    mdl_batch [input_filename] [output_filename] [solver_name] <options>
    https://help.altair.com/hwdesktop/hwx/topics/motionview/generating_solver_input_file_solving_frm_mv_mdl_batch_r.htm?zoom_highlight=motionview+batch
    For the post-processing, you can write TCL commands to open HyperGraph, plot either a PLT or ABF file, and then export the curves.
    Using Altair Compose (how I commonly accomplish this task), you could use the CAE Reader Tool to generate the syntax for extracting the desired curves from a PLT or ABF file, and then add a few more lines for writing to CSV and running the model.
    The alternative method, using Jupyter Notebook, can automate the creation, solving, post-processing, and reporting of models.
    This topic was originally discussed here:
    @Christopher_Fadanelli mentions:
    You can directly create a MotionSolve Jupyter Notebook session from the Start Menu in Windows or by invoking the respective script in Linux. After invoking the first Jupyter session the tutorials are being placed under:
    • Windows: C:\Users\{USER_NAME}\Documents\Altair\MotionSolveNotebooks\demos
    • Linux: /home/{USER_NAME}/Documents/MotionSolveNotebooks/demos
    The tutorials can also be found in your Altair installation folder:
    • {ALTAIR_INSTALL_PATH}\hwsolvers\demos\motionsolve\jupyter
    More details can be found in this second Community article:
    Hope this helps!
    Adam Reid
    User: "Thomas_"
    OP
    Hi,
    Thanks for you answer.
    Is Jupyter API can work with Motion View 2022.1 ?
    Thanks
    Thomas
    User: "GTT Adam"
    Altair Employee
    Hi @Thomas_Bécue,
    Unfortunately no, the Jupyter API for MotionView was not introduced until the 2024.1 release.
    https://2024.help.altair.com/2024.1/hwdesktop/hwx/topics/release_notes/rn_2024_1_motionview_r.htm
    Is it possible for you to update to the 2025.0 release? There are significant improvements that have been implemented since the 2022.1 version.
    Hope this helps!
    Adam Reid
    User: "Thomas_"
    OP
    Accepted Answer
    Hi !
    I found a alternative with a OML script on Compose 2022.1 to generate CSV files from my ABF files
    I placed all my .abf files in a folder, from which I want to extract the results in .csv format.
    What the OML script does :
    1. I specified the ABF folder path in the script, then I specified the folder path where I want to save my .csv file.
    2. I ran a loop that scan all the files in the "ABF" folder (the folder must only contain .abf files!) to generate a list of .abf files.
    3. Next, another loop takes the path to the [i] .abf file and loads it with the READMULVECTORS() function. You can specify the result to extract as an argument (see the OML documentation for this function to use it).
    4. I used this function a second time to load the TIME vector.
    5. I created the CSV file.
    Regards,
    Thomas
