Does other loads step affect the result of normal mode analysis?
Description: [I am studying optistruct, and I am doing the analysis of a bracekt with center mass load. I add 2 loadsteps , one is normal mode, and the other is Gload. I found the mode analysis result would be changed per the Gload analysis type. If the Gload analysis type is non-linear static, the modes will be 145HZ 220HZ 351HZ, but if
Gload analysis type is linear static , the modes will be 150HZ 235HZ 266HZ. And if I delete the Gload analysis load step and only keep the normal mode load step, the modes will be 150HZ 235HZ 266HZ. So I guess the result 150HZ 235HZ 266HZ is the correct result , but I don't know why the normal mode result will be affected by other load step. The attachments are the .hm files. thank you.]
Product/Topic Name : [hypermesh and optitruct 2023.1. ]
Theoretically, the normal mode results shouldn't be affected by the presence of another load step (without using PRELOAD), like your case.
I looked into your model, and it seems the contact is treated differently when there is a nonlinear static load step or not. That causes the difference.
I don't know exactly what difference in the treatment, but I can get a consistent result by using surface to surface contact (the default is node to surface contact). More details can be found at
I attached my model and result using surface to surface contact for your reference.
forget to attachment the .hm files
