Altair RISE
Nominate Yourself Now!
Running DSim from command line
User: "red_elephant"
Altair Community Member
I'm using Ubuntu 24.04 on WSL and I have installed DSim there. I'm trying to run an UVM AXI VIP I found on GitHub. There is a makefile there and this makefile runs DSim from the command line. When I do “make” I get this error:
dsim: error while loading shared libraries: libdummy_exports.so: cannot open shared object file: No such file or directory
Can someone explain to me what should i do?
Thank you so much!
1 - 9 of 91
    0
    Hi.
    The issue is that you have not sourced the shell_activate.bash file in the directory where you have installed dsim. If that doesn't work, can you send us your env? Do a env > env.txt and send us the env.txt file. Thanks.
    0
    OP
    It didn't work.
    We are looking for the LD_LIBRARY_PATH being set properly, which it isn't. Also DSIM_HOME should be set. Here is what you need to do:
    source /home/user/AltairDSim/2025/shell_activate.bash
    env | grep DSIM_HOME
    dsim -version-verbose
    If those three commands work, then you should be fine. If you have other terminals, you need to do the source command in them as well, if you want DSim to work there.
    OP
    source /home/user/AltairDSim/2025/shell_activate.bash output: Activating DSim version: 2025
    env | grep DSIM_HOME output: DSIM_HOME=/home/user/AltairDSim/2025
    dsim -version-verbose output: 2025.0.0000 (b:S #c:32 h:e6a01125e5 os:centos_8)
    Copyright (C) 2017-2025 Altair Engineering Inc. All rights reserved.
    but still when I run Makefile I get this error:
    make SIMULATOR=dsim
    make sim_dsim TEST=default
    make[1]: Entering directory '/home/user/tvip-axi/sample/work'
    [ -f dsim_work/image.so ] || (make compile_dsim)
    make[2]: Entering directory '/home/user/tvip-axi/sample/work'
    dsim -genimage image -uvm 1.2 -l dsim_comp.log -timescale 1ns/1ps +define+UVM_NO_DEPRECATED +define+UVM_OBJECT_MUST_HAVE_CONSTRUCTO -top top -f /home/user/tvip-axi/tue/compile.f -f /home/user/tvip-axi/tvip-common/compile.f -f /home/user/tvip-axi/compile.f -f /home/user/tvip-axi/sample/env/compile.f /home/user/tvip-axi/sample/env/tvip_axi_sample_delay.sv /home/user/tvip-axi/sample/env/top.sv
    =N:[UVMSource] Using sources from '/home/user/AltairDSim/2025/uvm/1.2'
    License error:
    Altair License Manager: License error
    Feature(s): GlobalZoneEU, HyperWorks, HWDSim
    Error Code: 15
    Error Description:
    [NETWORK] 6200@localhost - (Err: 15) Unable to connect to license server
    193
    =E:[UsageMeter (2025-05-07 17:55:38 +0300)] Altair License Manager: License error
    Error Code: 15
    Error Description:
    =F:[UsageMeter (2025-05-07 17:55:38 +0300)] Could not acquire Altair license; exiting.
    User: "pdhakal"
    Altair Employee
    Updated by pdhakal
    Could you please run this command:
    env | grep ALTAIR
    You should get "ALTAIR_LICENSE_PATH=…"
    It should be set to a valid license file if this is a standalone setup. But if you are running a license server locally (which is suggested by "6200@localhost", then you need Altair License Utility to be configured locally and you need to have imported the license file into the license utility. Additionally, the service (named Altair License Server on Windows — the daemon is probably named similarly in linux) needs to be running.
    Note: edited for clarity and to remove incorrect information about almutil.
    OP
    Updated by red_elephant
    env | grep ALTAIR
    ALTAIR_LICENSE_PATH=/home/user/AltairDSim/2025/dsim-license.json
    I set my dsim-license.json file as an environment variable for ALTAIR_LICENSE_PATH. Now I get this error, I did not change anything in my license file:
    make SIMULATOR=dsim
    License error:
    Error Code: 9
    Error Description:
    Feature not found
    Feature: DSim
    Error Code: 4
    Error Description:
    [LOCAL] /home/user/AltairDSim/2025/dsim-license.json - (Err: 4) License file is using unknown/invalid syntax
    License Path: /home/user/AltairDSim/2025/dsim-license.json
    347
    =E:[UsageMeter (2025-05-08 15:57:19 +0300)] Altair License Manager: License error
    Error Code: 9
    Error Description:
    Feature not found
    Feature: DSim
    Error Code: 4
    Error Description:
    =F:[UsageMeter (2025-05-08 15:57:19 +0300)] Could not acquire Altair license; exiting.
    User: "pdhakal"
    Altair Employee
    Accepted Answer
    The fact that the license file is a JSON file suggests that you are using the legacy Metrics license. To use the legacy license, you need to export DSIM_LICENSE:
    export DSIM_LICENSE=/home/user/AltairDSim/2025/dsim-license.json
    The presense of this environment variable lets dsim know that you wish to use the legacy licensing model.
    OP
    The "legacy Metrics license" that pdhakal refers to is what is currently known as the "Free Individual License":
    https://help.metrics.ca/support/solutions/articles/154000146984-licensing
    The setup required for using DSim outside of DSim Studio is documented in the DSim Quick Start Guide:
    https://altairone.com/Marketplace?queryText=dsim&tab=Documents&app=DSim
