Running DSim from command line
User: "red_elephant"
Altair Community Member
I'm using Ubuntu 24.04 on WSL and I have installed DSim there. I'm trying to run an UVM AXI VIP I found on GitHub. There is a makefile there and this makefile runs DSim from the command line. When I do “make” I get this error:
dsim: error while loading shared libraries: libdummy_exports.so: cannot open shared object file: No such file or directory
Can someone explain to me what should i do?
Thank you so much!
1 - 1 of 11
    User: "pdhakal"
    Accepted Answer
    The fact that the license file is a JSON file suggests that you are using the legacy Metrics license. To use the legacy license, you need to export DSIM_LICENSE:
    export DSIM_LICENSE=/home/user/AltairDSim/2025/dsim-license.json
    The presense of this environment variable lets dsim know that you wish to use the legacy licensing model.
