🎉Community Raffle - Win $25
Join and Win
6 Ph PMSM Field Oriented Control
User: "Robe 4"
Altair Community Member
I try to drive 6 phase PMSM as generator. I am using field oriented control. I can do that succesfully with 6 phase pmsm with no phase shift. However when ı switch to 6 ph pmsm with phase shift block, system goes out of control. By the way to solve problem, I try different position phase shift for dq domain transformation.
Is there program bug or how can ı run simulation properly?
1 - 2 of 21
    Dear User,
    PSIM's 6-Ph PMSM Block (spatially shifted by 30°) is physical and should work even when used as a generator. In fact, there is a quick example inside PSIM that highlights this.
    You can navigate to Help >> Index >> 6-ph PMSM generator to test it.
    Could the issue you're experiencing be related to the control setup?
    BR,
    Nikos
    User: "Robe 4"
    OP
    Thak you for the answer, Nikos.
    I know the quick example and ı checked it before create this post.
    Source of problem may be related to control blocks, however, ı dont think so. Because when ı use 6 ph PMSM Block (zero phase shift), same system work properly.
    On the other hand, If ı use 6 phase-shifted PMSM Block, I only add 2*pi/12 phase shift for the XYZ phase dq domain transformation. And these system goes unstability, immediately.
    Could the issue be related to the PSIM related?
