🎉Community Raffle - Win $25
Join and Win
Get System id using TCL
User: "Meiyarasu@2410"
Altair Community Member
Description: i am trying to get the system id assigned to an CBUSH element using hm_getentityvalue command like the following,
set prop_id [hm_getentityvalue elems $elem_id "propertyid" 0 -byid].
please help me with this
Product/Topic Name : Hypermesh, TCL, script
1 - 4 of 41
    what solver are you using?
    If you're suing OptiStruct, and CBUSH, you could use something like
    hm_getvalue elements id=$elem_id dataname=CBCID
    Usually I take one of the entities in my model, and I run the attached script from the installation.
    With this script, you pick one entity of your model, and it will show the datanames specific to the solver, that you can call from the hm_getvalue command.
    For other basic values you could use the basic datanames:
    % hm_getvalue elems id=2 dataname=collector
    2
    % hm_getvalue elems id=2 dataname=collector.name
    CBUSH1D
    % hm_getvalue elems id=2 dataname=node1
    1
    % hm_getvalue elems id=2 dataname=node2
    5
    % hm_getvalue elems id=2 dataname=property.id
    2
    % hm_getvalue elems id=2 dataname=property.name
    PBUSH1D
    OP
    Thank you for the information.
    i am using Nastran solver. i will try CBCID command. will it work in Nastran solver?
    User: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    yes, it is the same.
    Run the entity_attribute_table.tcl to get the datanames associated to any entity in HM.
    OP
    Thank you so much
