cweld conversion (from elemid to partpat)
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
i use fe absorb to absorb nastran cweld (nastran80-88 type) then unrealize all of them.
then i change weld type from elemid to part pat and realize it.
at the end, i lose GS value of cweld elements. What could i do ? what is wrong with these method ?
thank a lot
mustafa
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2010
    Are you realizing with the correct config? The 'GA-GB PARTPAT' config doesn't populate the GS value. Only the 'GS PARTPAT' does. Both configs are considered part pat.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    i am sure i realize with GA-GB PARTPAT and i recieve following errror. i check the manual
    ** USER FATAL MESSAGE 316 (IFPDRV)
    ILLEGAL DATA ON BULK DATA ENTRY CWELD
    CWELD 6765647 2 PARTPAT 954511 954512 +000C09
    ++000C095447 5447 +000C0A
    format is like that
    CWELD EWID PWID GS 'PARTPAT' GA GB
    PIDA PIDB
    XS YS ZS
    also I check the card/elems in hyper. then i see GS=0
    so i conclude there is missing GS value ?
    regards,
    mustafa
  • Altair Forum User
    Altair Forum User
    Altair Employee
    For this config GS should be blank, so I don't think that is the problem. Just for clarification, are you using Radioss bulk for the solver? Looks like you were using a Nastran configuration previously.
    If so, try puptting a connection location in the card and see if that works. (yours are blank, or you did not include the third line) If it does, then I will check on why those fields are not being populated.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    i use nastran as a solver.
    i put the G5 value manually but it gives error again.
    *** USER FATAL MESSAGE 316 (IFPDRV)
    CWELD 6757874 2 934009PARTPAT 940476 940477 +000BNF
    ++000BNF5447 5447 +000BNG
    GS=934009
    so GS is not problem but what it is ?
    regards,
    mustafa
  • Altair Forum User
    Altair Forum User
    Altair Employee
    You will have to check the NASTRAN manual for details on this error message.
    I was referring to manually populating the XS, YS, and ZS fields, as it looks like they are required for the option you are trying to use. Leave GS blank.
Welcome!
Welcome!
