🎉Community Raffle - Win $25
Join and Win
Radioss solver pressure load application
User: "Sourav_Kumar_Das"
Altair Community Member
I have a problem with the pressure load application with the Radioss solver, load constraints. I want to apply a constant pressure load of X MPa on a solid cylinder's top surface area in order to apply the load to a solid sphere, which is kept in between two cylindrical surfaces, i.e top part is the impactor and the bottom part is fixed. So , as there is provision for applying the pressure load, how is it applied, and what are the contact definitions used for which the solid sphere is getting deformed by the application of the constant pressure load. I am unable to apply the pressure load application. so please suggest how to overcome the problem.
1 - 10 of 101
