In element quality, i can check the elements that are not satisfied with the requirement in the legend tab on the right.
Other elements are not displayed, and only the unsatisfactory elements are output.
When I check the element quality again after doing several tasks, unnecessary elements are displayed in transparent gray.
Is there a way to turn this off?
When I delete the settings file, it is restored to the original state, but sometimes it doesn't and it does whatever it wants.
Thank you
