Hello
I am currently using version 19, but I am studying version 24 for the future.
In version 19, the "by face" function is used to select the part connected to a specific surface.
In version 24, it has been changed to the "attached faces" function.
I use this function quite a lot.
I want to set this part as a shortcut key, but I can't find it in the shortcut key setting options.
Is there a way to do this?
