Altair RISE
Nominate Yourself Now!
why the value of outlook in correlation matrix is “?”
just run this
 you will get this
1 - 4 of 41
    User: "RolandJones"
    Altair Employee
    Hi @AP,
    This is because the value can only be calculated when the attributes are numerical or binominal. Outlook is Nominal, and hence a correlation can't be calculated.
    Thanks,
    Roland
    “the value can only be calculated when the attributes are numerical or binominal. Outlook is Nominal, and hence a correlation can't be calculated.”—-why?
    User: "RolandJones"
    Altair Employee
    The statistical method of calculating correlations doesn't support categories, referred to as nominal in AI Studio.
    Hope this helps,
    Thanks,
    Roland
    “The statistical method of calculating correlations doesn't support categories”,but “binominal” is a kind of categories
