just run this
you will get this
why the value of outlook in correlation matrix is “?”
Hi @AP,
This is because the value can only be calculated when the attributes are numerical or binominal. Outlook is Nominal, and hence a correlation can't be calculated.
Thanks,
Roland
“the value can only be calculated when the attributes are numerical or binominal. Outlook is Nominal, and hence a correlation can't be calculated.”—-why?
The statistical method of calculating correlations doesn't support categories, referred to as nominal in AI Studio.
Hope this helps,
“The statistical method of calculating correlations doesn't support categories”,but “binominal” is a kind of categories
