🎉Community Raffle - Win $25
Join and Win
Trying to Import Pressure Load from a .csv File and Radioss
User: "RomainMegret"
Altair Community Member
Hello
I'm trying to import a pressure field that I obtained from a CFD solver. This pressur field is registered in a 4 columns .csv (x,y,z,P).  In Hypermesh, I go in Analysis and then pressures. here I select my faces and the option "Linear Interpolation" . Therefore I choose my .csv and at first sight it seems to work. However, once in Radioss, my Pressure Load doesn't appear in the *_0000.rad file.
Do you know how could i solve this issue? Thanks in advance.
