Default settings for Member Mesh
SLadisch
SLadisch Altair Community Member
Hello,
I have a more or less simple question. Is there a possibility to define the default settings for the Memeber Mesh module? Maybe by using the hm_custom.tcl or a custom extension?
Regards
Stefan
Welcome!
Answers
  • Michael Herve
    Michael Herve
    Altair Employee
    Hello @SLadisch ,
    which settings would you like to save and restore from one session to another one?
    Best Regards,
    Michael
  • SLadisch
    Hello Michael,
    The module "Member Mesh" starts in new sessions with element type BEAM and a certain mesh distance. We usually use this module to define Rod-Elements along a weld (node list). So we always need to change the settings. First from line to node list and then to ROD and "by density"
    Regards Stefan
    2025-03-26 10_19_38-Kassel-TB_2025-03-26.hm_ - Altair HyperMesh 2024.1 - OptiStruct.png
  • Michael Herve
    Michael Herve
    Altair Employee
    Hello @Stefan Ladisch,
    there is no core option yet to change default preferences for member mesh.
    That said it should be pretty straightforward to create a tcl or Python script with your preferred settings.
    i just had a quick look at command.tcl , you can basically use 2 lines:
    *createlistpanel nodes 1
    *createelements1d nodes list=2 elemsize=0.045 engineeringconfig=ROD propcardimage=PROD linecomp=0 useshell=0 biasintensity=0 biasstyle=0
    Please run interactively Member size with your own settings to adjust the 2nd line above
    Regards,
    Michael
  • SLadisch
    Hello Michael,
    It's too bad that there is no possibility to define a default or that the software doesn't save the last state of the dialog as a hidden user preference. Perhaps you could suggest this to your development colleagues.
    Based on your suggestion, I created a function within our own extension, so now we can directly create ROD elements from a node selection.
    namespace eval ::ROD_Mesh {
    proc ::ROD_Mesh::ROD_Mesh {} {
    *createlistpanel nodes 2 "Select nodes for the ROD-line:"
    set node_list [ hm_getlist nodes 2 ];
    if { ! [ Null node_list ] } {
    *createelements1d nodes list=2 useelemdensity=1 elemdensity=1 engineeringconfig=ROD propcardimage=PROD linecomp=0 useshell=0 biasintensity=0 biasstyle=0
    Regards
    Stefan
Welcome!
Welcome!
