RESTARTW \multiple independent nonlinear subcases. Nonlinear restart requests are not supported.
David_R
David_R Altair Community Member
edited March 17 in Community Q&A
*** ERROR # 4762 ***
There are multiple independent nonlinear subcases. Nonlinear restart
The model is steel, with plastic, non-linear properties.
Without RESTARTW the model runs fine.
With RESTARTW this error message appears.
How can RESTARTs be not supported?
Best Answer
  • David_R
    Answer ✓
    I discovered Optistruct needed CNTNLSUB.
    With CNTNLSUB the subcases will be sequential & not independent.
    So this problem is resolved now. Thanks
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    What version are you using?
    please, have a look at these:
    Requirements for Restarting
  • David_R
    Answer ✓
Welcome!
Welcome!
