🎉Community Raffle - Win $25
Join and Win
Composite failure constraints
User: "SSnell"
Altair Community Member
Updated by SSnell
Hi, I'm optimizing a composite model and I want to constrain the failure.
I created the composite failure response and then created the constraint applied to all of my loadcases with an upper bound of 1.
I don't see CFAIL as an output option in control cards so added CFAIL(ALL) = ALL to the .fem file or in CASE_UNSUPPORTED_CARDS  in control cards.
Observing the results in hyperview show that only ply failure is observed by the optimization and that bond failure is not.
Is there a different form of  failure constraint that would allow the optimization to adhere to bond failure as a constraint?
Thanks,
1 - 5 of 51
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi,
    Can you try CFAILURE instead of CFAIL as shown in the image below, please?
    User: "SSnell"
    OP
    Updated by SSnell
    My mistake, I meant to say *CFAILURE in my original post, that's what I have been using. is there another constraint to make bond failure a constraint?
    Altair Employee
    Hi SSnell,
    there is only composite failure available.
    I will check if there is a work around to use bond failure as a response and will get back to you soon.
    Altair Employee
    BTW, which failure criteria are you using for your analysis?
    User: "SSnell"
    OP
    Updated by SSnell
    Thanks a lot for the reply, I'm using Tsai-Wu, the failure response is composite failure, and The upper bound for the constraint is 1.
    A work around for bond failure would more than answer my question. Thanks
