Material system does not appear in matrix Browser and Hyperview
Sebastian Yang
Sebastian Yang Altair Community Member
edited March 19 in Community Q&A
Edit: it has been solved, it´s because the result math template was set to standard instead of advanced.
—original post—
Hello,
We are having a problem with the 2021.1 version of hypermesh in our company. One of my collogues is having this problem, when he launches Matrix browser and select elements, then load cases, then the coordinate system, the material orientation option does not appear, as shown in the following figure:
but in my case, when I launch this matrix browser, I do see the material system option:
Also when he tries to show the stress in material orientation in hyperview, this option doesn´t show either, see image below:
What could be the reason behind this strange situation?
Just to add a little context, he had some problems with the installation process but evetually he got it to work…
Thank you in advance.
Answers
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    Thanks for confirming the issue is resolved as others can benefit from this
Welcome!
Welcome!
