In Flux motor V2025 I can't Load original WFSM examples from the motor catalog to an editable user catalog for both libraries Auto and generator, the below error message pop up.
attached also error log
Any help is really appreciated, I would like to test the generator example.
Hi,
Sorry for the delay. I have the same behavior as you. It is A FluxMotor issue ‘our FluxMotor team are aware of it and the issue will be fixed in the future versions).
One workaround that I can propose to you is to delete the folder simulation in your motor)
Double click on Gen-120510P and delete the folder simulations (this allows you to open the model but if you have any saved results they will be deleted).
Thanks.
