I am trying to simulate a rectangular waveguide (WR-34) from 18-40GHz and I receive the following error
The model is attached in the file.
Hi @niharika_kaja
The folder you attached is empty. Can you please upload it again?
Thanks,
Zeina
I have uploaded the file
Hi @niharika_kaja ,
I opened the file and noticed that it has not been meshed due to Feko not being able to access the Temp folder. Please check if the Temp directory has read/write permissions.
As far as the model goes, there are no issues with the geometry. I was successfully able to run the model in Feko v.2025. Please find the results attached.
Regards,
Shannon Mistry
Join us for a community conversation on Pulse Width Modulation (PWM), a fundamental technique in electric motor control, and explore how different PWM strategies can yield significantly different results. This webinar provides a comparative analysis of various PWM methods and their effects on motor efficiency, torque…
Join us for a community conversation to discover the Advanced Iterative Solver(AIS) in Simcenter Feko and its application to electrically large and computationally demanding electromagnetic models. The session will provide a general overview of how iterative solution methods can help improve efficiency of large scale…
