How to map variable pressure distribution on a surface
User: "Shawn Goh"
Altair Community Member
Updated by Shawn Goh
Hi, I want to map a distribution of pressure over a bicycle saddle based on the weight of a person seating on it. As it is not a constant load distributed over the area, how can I implement the distribution of pressure with a varying load or a load that changes (i.e. starts from a reference point and slowly reduces as it is spread over an area)?
Is there a function I must use or reference a table of data? Would really appreciate the help. Thank you.
