PSIM Gating Block for non-ideal MOSFET
Oscar_Mike619
Oscar_Mike619 Altair Community Member
Howdy PSIM users
I am using Gating blocks to generate unique patterns of PWM signals to drive switches in my converter.
This works well for ideal switches however I need to use the same PWM sequence for Level-2 MOSFET models, which is not supported.
Please advise.
Welcome!
Answers
  • VSiddhartha
    VSiddhartha
    Altair Employee
    Hi,
    For level2 MOSFE need to select "control to model" as shown in figure.
    This might be one of the possible errors. Please check once.
    Further, a detailed article on switches is available here:
    PSIM switch models: Choose Wisely! — Altair Community
    Thank you,
    Vishwanatha Siddhartha
  • Oscar_Mike619
    Thank you for your response
    I am aware of the "control to model" option in the on-off controller block.
    I am using "a Gating block," which is like a lookup table on turn-on and off times.
    I am using this because I am implementing a unique switching pattern, which cannot be emulated by voltage sources.
    However it only allows direct connection to the gate of an ideal FET/ switch. It will not connect directly to a level 1/ 2 model or to an "on-off controller- multi-level" block.
  • VSiddhartha
    VSiddhartha
    Altair Employee
    Hi,
    It would be helpful to have the schematic file or any sample schematic, as it is difficult to fully understand this without it.
    Thank you,
  • Ju4n_R0sales
    Ju4n_R0sales
    Altair Employee
    Hi Oscar!
    An alternative I can think of is using the piecewise linear source + a resistor. Another option is using a lookup table and a controlled voltage source. In both cases you would need to define points in time instead of an angle in degrees.
    We'll ask around maybe there's another solution.
    • Juan
  • NikosDimitrakopoulos
    Altair Employee
    Hi all,
    Based on Juan's comment, you could drive the gate like this:
    The LuT should contain time vs Vgate info. You can find more details about LuTs here: https://community.altair.com/discussion/38451
    BR,
    Nikos
  • Oscar_Mike619
    Thank for the responses.
    I am doing the following: As the "Gating block" can only drive ideal FETs, I am driving an ideal FET with it, and inverting the drain terminal voltage to the input of a "multi-level on-off controller".
    A suggestion to the devs: the "Gating block" should have a mechanism of driving non-ideal FETs.
Welcome!
Welcome!
