🎉Community Raffle - Win $25
Join and Win
Can I use save/load functions in the python API?
User: "Keelan_Brydon"
Altair Community Member
Hi there,
I am working with the Psim-Python API, and I would like to use the PSIM "save" function to pause and save my state in the simulation, and then the "load" function to continue the simulation from where I left off. I am wondering if it is possible to set the save and load flags through python?
1 - 2 of 21
    Hi @Keelan_Brydon,
    I know this is possible using the legacy PSIM scripting method with C. The same functions should be implemented with the Python API, so I will suggest the approach we have used until now.
    You can navigate to Script » Script Tool » Help » Simulation Functions»Simulate
    Looking forward to your feedback.
    BR,
    Nikos
    User: "Ignacio_Santana"
    Hi NikosDimitrakopoulos,
    @Keelan_Brydon and I were working using the Python API, but when we call the simulation from Python using the command below, the system doesn't save the simulation:
    d3 = dict(Simview=-1, proportional_gain=kp, intergral_gain=ki, vout_set_point_volts=48
    , buck_inductor_H=0.1e-3, buck_capacitor_F=0.1e-3, switching_frequency_hz=100e3,
    TOTALTIME = SIM_TIME, SAVEFLAG = 1)
    result = psim.PsimSimulate(BUCK_SIM_SIMULATION_FILE, BUCK_SIM_RESULT_FILE_SMV, **d3)
    Please let us know if we are doing something wrong, or if there is another way of doing it. the version of the package we are using is 2024.0:
    name='psimapipy',
    description='A Python package for Altair PSIM Python APIs and commands',
    version='2024.0',
    url='https://www.altair.com/PSIM',
    author='Altair Engineering',
    packages=['psimapipy'],
    package_data={"psimapipy": ["*.pyc"]}…
    Thank you very much,
    Ignacio
    Dear @Ignacio_Santana,
    We identified an issue with the Python Save/Load flags. Here is a workaround until the issue is fixed in next version with expected release in May:
    Please don't skip  "-i"  "-o"  "-v"
    As it won't work without them
    Hope this helps!
    BR,
    Nikos
    Dear NikosDimitrakopoulos,
    Thank you for sharing this information. We'll Save/Load our simulation using this command until the new version is released.
    Thank you again,
    Ignacio Santana
