The following ERROR was detected: -4 Number of zero or negative pivots:***
Mugundhan_5995
Mugundhan_5995 Altair Community Member
I need the elastic constant for FRP honeycomb, so I just modeled and did a periodic mesh to the CAD, then imported it into MSD after entering the elastic constant for the fiber and entered the RUN option (during the run, the error has shown).
*IN LINEAR MATERIAL CHARACTERIZATION*
Answers
  • GTT Johan
    GTT Johan
    Altair Employee
    Hi Mugundan
    You need to make sure that the mesh is periodic in xyz!
    Easiest way to do that is to mesh 1/8th and reflect mesh in Hypermesh!
    //Johan
Welcome!
Welcome!
