1 - 4 of
41
Of course. :)
The question is related to HyperMesh 2024.1
I have a further clarification, which is maybe needed to answer my question. I don’t need to move the parts in my model in relation to each other using the Move tool. I need instead to turn the model in a particular way to create a picture of it. However, I don’t want to do this by hand, since it’s too unprecise, so I need this custom rotation. I read something about a so called “Manipulator” which is used for this purpose, but I couldn’t find this tool in HyperMesh.
Thank you all in advance for your help.
Hi @Toni_Georgiev ,
If you specify which tool you are asking about, by adding a TAG to your question or mentioning the tool, then someone will be able to assist.
Best,
Zeina
