🎉Community Raffle - Win $25
Join and Win
Cylindrical BC for RADIOSS
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi everybody,
is it possible to assign a Radioss' BCs to a cylindrical system?
Regards,
Luke31
1 - 7 of 71
    Altair Employee
    OP
    I asked it because it seems that the assignment to a cylindrical skew didn't work for my simulation in Radioss.
    Altair Employee
    OP
    Hi Luke,
    RADIOSS doesn't support to assign boundary conditions in a cylindrical coordinate system now. But to work on it, you can select the nodes and put imposed displacement (/IMPDISP, and keep icoor=1),for each dof with zero magnitude function.
    Altair Employee
    OP
    it didn't work. I gave a displacement in the radial direction and my geometry moves in the z-direction, even if I asigned all nodes and loads to the local system that I want. Morever, the resulting movement is also strange if i consider the global coordinate system. Here the model attached.
    Altair Employee
    OP
    Hi Luke,
    Based on the loading conditions in the model, I made slight modifications. Can you check the model attached along.
    Altair Employee
    OP
    now the direction are correct. What modifications do you make?
    Moreover I changed the direction of the IMPDISP along the X direction (by changhing the 'y_scale' from 1 to -1) and during the simulation contacts are deactivated. why does this happen?
    Regards,
    Luke31
    Altair Employee
    OP
    Hi Luke,
    Did you constrain the upper component in X direction?. Also review the interface created.
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Hi Luke,
    @Prakash Pagadala
    Does radioss still dont support assigning BC in cylindrical coordinate?
