How to create / define Rigidbodies in Optistruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo Team,
I am using Optisruct 2017.2 for Transient Analysis and I request your help for the following problems:
1. My model contains bearings, for which i need to assign/create as rigidbody. How do I create?
2. Is transient analysis be performed in Optistruct?
Thanks in advance.
1 - 7 of 71
    User: "tinh"
    Altair Community Member
    Updated by tinh
    1.Did you try using 1d>rigid
    2.Yes, you can refer to OS reference guide examples OS-1310, OS-1315
    Altair Employee
    OP
    Hi Tinh,
    Thanks for your reply.
    1. I haven't tried using 1D's. I created using Rigidbodies ( RBODY ).But I am facing problems with ref.node. in PRBODY card.
    2. I will go through the above mentioned tutorials.
    Regards,
    Rajasekhar
    User: "tinh"
    Updated by tinh
    As I looked up OS reference guide, PRBODY is used for Multi-Body Simulation
    maybe it's not suitable for Transient Analysis
    panel 1d>rigid will create RBE2 binding all nodes of the bearing component, it will become rigid
    Altair Employee
    OP
    Hi Rajashekar,
    Could you please let us know what are all the problems you are facing with RBODY in OptiStruct?
    Altair Employee
    OP
    PROBDY is used to do the Multi-Body Simulation.
    Maybe you can share the file for us to try RBE2 elements.
    It is a method about MPC constrained.
    Altair Employee
    OP
    Hi Prakash,
    For example : My model consists of Radiator fan assembly.
    Parts in the assembly : Fan+Spindle+Bracket
    I have to Analyse the Bracket in transient case.
    >> bracket and spindle are connected through bolts/screws
    >> I considered Fan as rigid, since it is not my area of interest.
    >> Modelling rigid : Rbodies
    create element/node set for the Fan
    now create RBODY
    assign the element / node set of fan in ELEMENT sets
    I have selected node1 as my ref node
    load steps, controls cards are defined.
    Try 1 : for ref node1 >> my solution says RUNNING. If I check the run status after 1 hr, It still says RUNNING but i my OUT file shows as in pic attached below.
    Try 2 : for ref node2 >> i got the results
    Try 3 : for ref nodes 3, 5, 4 >> same scenario as in TRY1
    So what is the criteria for ref node selection for RBODY???
    Regards,
    Rajasekhar
    User: "tinh"
    Updated by tinh
    Note #6 of RBODY card:
    if you provide Ref node, please provide mass
    otherwise, do not provide ref node
