How to create / define Rigidbodies in Optistruct
Hallo Team,
I am using Optisruct 2017.2 for Transient Analysis and I request your help for the following problems:
1. My model contains bearings, for which i need to assign/create as rigidbody. How do I create?
2. Is transient analysis be performed in Optistruct?
Thanks in advance.
Hi Tinh,
Thanks for your reply.
1. I haven't tried using 1D's. I created using Rigidbodies ( RBODY ).But I am facing problems with ref.node. in PRBODY card.
2. I will go through the above mentioned tutorials.
Rajasekhar
Hi Rajashekar,
Could you please let us know what are all the problems you are facing with RBODY in OptiStruct?
PROBDY is used to do the Multi-Body Simulation.
Maybe you can share the file for us to try RBE2 elements.
It is a method about MPC constrained.
Hi Prakash,
For example : My model consists of Radiator fan assembly.
Parts in the assembly : Fan+Spindle+Bracket
I have to Analyse the Bracket in transient case.
>> bracket and spindle are connected through bolts/screws
>> I considered Fan as rigid, since it is not my area of interest.
>> Modelling rigid : Rbodies
create element/node set for the Fan
now create RBODY
assign the element / node set of fan in ELEMENT sets
I have selected node1 as my ref node
load steps, controls cards are defined.
Try 1 : for ref node1 >> my solution says RUNNING. If I check the run status after 1 hr, It still says RUNNING but i my OUT file shows as in pic attached below.
Try 2 : for ref node2 >> i got the results
Try 3 : for ref nodes 3, 5, 4 >> same scenario as in TRY1
So what is the criteria for ref node selection for RBODY???
Rajasekhar
1.Did you try using 1d>rigid
2.Yes, you can refer to OS reference guide examples OS-1310, OS-1315
