Geometry problem when meshing after modifying BLDC example
sw07
sw07 Altair Community Member
Hello.
I want to change the BLDC coil shape and analyze it, so I changed the coil shape of the basic example file as follows. (Proceeded with the example that progressed to physics)
And when I performed the mesh, the following message appeared.
- output message -
List of linked faces without source face (geometry):
112 113 114 115 116 117
Mesh informations are not consistent. Meshing is arborted.
The above face number is the newly drawn coil geometry as shown in the figure below, but I wonder how to solve it.
Please reply.
Thank you.
Welcome!
Best Answers
  • asoualmi
    asoualmi
    Altair Employee
    Answer ✓
    Hi,
    Which mesh information do you use on these faces? Can you try to do it without any mesh information on the faces?
    Also when you create the other faces , the initial (112 113 114 115 116 117)faces are used as reference?
    thanks
  • asoualmi
    asoualmi
    Altair Employee
    Answer ✓
    Hi,
    Can you share the mdoel?
    thanks
Answers
  • asoualmi
    asoualmi
    Altair Employee
    Answer ✓
    Hi,
    thanks
  • sw07
    Hello.
    I modified the BLDC basic model provided by Altair,
    so I don't know what mesh information is used,
    and I think the initial (112 113 114 115 116 117) faces are used as a reference when creating other faces.
    Please explain from the perspective of modifying the BLDC basic model.
    Thank you.
  • asoualmi
    asoualmi
    Altair Employee
    Answer ✓
    Hi,
    thanks
  • sw07
    Hello.
    I don't know what happened, but I saved it and ran it again the next day, and the error didn't appear, so I can't give you the data.
    Thank you for your kindness, and I will send you the data next time.
    Best Regards
Welcome!
Welcome!
