Hi,
I am a new user of radioss. I tried running dynamic Impact Analysis case of bullet hitting wall. The solver is running and giving result.
But there is no animation file generated in the output folder . I have attached the rad files too. Kindly guide me for this case
You need to add requests in your engine file for animation, here is a simple example for your run:
/ANIM/DT sets output frequency,
The other /ANIM cards request velocity, displacement and stresses
see this section of help: Anim Requests in Help
