Converting PCOMP/PCOMPG to PCOMPP
jerometeoh
jerometeoh Altair Community Member
Hi,
Is there a simple way to convert a PCOMP/PCOMPG composite model into PCOMPP?
Which allows me to easily changing the stacking sequences?
Best,
Jerome.
Welcome!
Best Answers
Answers
  • Michael Herve
    Michael Herve
    Altair Employee
    edited January 30 Answer ✓
  • jerometeoh
    Michael,
    Thank you for this.
    I cannot find the script in my pc.
    But I think I found out that as I am using HyperMesh 2023.1.
    Looks like I can just execute 'absorb' within the composite browser, it should yield the same result?
    Best,
    Jerome.
  • Michael Herve
    Michael Herve
    Altair Employee
    Hello @jerometeoh ,
    did you download the script available as attachment in th elink I shared with you?
    Best Regards,
    Michael
  • jerometeoh
    Hi @Michael Herve_21439 ,
    I just found the script, it is useful thank you! I like how it executing it one-by-one.
    I was trying to use this to convert PCOMP to PCOMPP for some filiment winding pressure vessel application. I am wondering if you ever do that?
    Also, how do people typically use 'wound' ply type?
  • jerometeoh
    Very thank you for the script!!
  • Michael Herve
    Michael Herve
    Altair Employee
    Answer ✓
    hello @jerometeoh ,
    “WOUND” is used to represent the filament winding process, where typical coverage of a “ply” can have all of spatially varying thickness and orientation on a spatially varying number of layers.
    WOUND today is usually populated from external manufacturing software. It’s just a datastructure though, and if your company has a manufacturing process from which they want to pass data which is spatially varying (including number of layers per “ply”), it can be populated via script.
    Hope that helps,
    Michael
  • jerometeoh
    @Michael Herve_21439 thank you for the clarification!!
Welcome!
Welcome!
