Press-Fit Contact modeling in Simlab using Optistuct Solber
Hi,
does anyone know how to model a pressfit contact in Simlab using Optistruct Solber?
Thank you.
Best regards
I am trying to do shaft with rotor interference fit simulation in order to ensure the considered interference is enough to withstand the torque load.
Load steps are
step 1 —> interference fit between rotor and shaft
step2—>thermal load
step3—>torque load
step4—>combination of torque+ thermal+ interference
please share some learning models related to this simulation
Hi MATHIAZHAGAN.
You can find some discussions in the community with good insights, I believe.
Try them and let the community know if you struggle.
https://community.altair.com/discussion/5105/to-find-the-torque-required-to-loosen-the-interference-fit?utm_source=community-search&utm_medium=organic-search&utm_term=interference+fit
https://community.altair.com/discussion/39477/modelling-interference-fits-and-validating-results
