How to simulate a impact Wrench Mechanism in Altair Motion View / Solve ?
Sivaprakash_V
Sivaprakash_V Altair Community Member
edited January 22 in Community Q&A
I have a Impact wrench mechanism CAD and I want to simulate it in Motion Solve / view then extract the loadings like force, torque etc….
Then use that loadings for FEA Analysis , also I would like to model a Flexible Body to obtain a Stress and Strain Result in Motion Solve.
I have one you tube Tutorial link which contains the Impact wrench Mechanism simulation tutorial performed using Siemens NX Motion. i want to replicate the same in Motion view/solve.
How to do it in Motion solve ?
You tube Link : https://www.youtube.com/watch?app=desktop&v=OFtopvX5Vvw
Thanks & Regards,
Sivaprakash. V
Welcome!
Best Answers
  • Vishvam
    Vishvam
    Altair Employee
    edited January 22 Answer ✓
    Hello @Sivaprakash_V
    If you are already familiar with using Motionview/Motionsolve, its a fairly easy mechanism to simulate by creating few joints/constraints, contacts and forces.
    If you are a beginner please go through the following eLearning for Motionview:
    https://learn.altair.com/enrol/index.php?id=496
    The eLearning would provide a deeper insight in creating Motionview entities.
    Once the basic mechanism is working as expected. You can integrate the flexible bodies created using the in-built Flexprep tool, and exporting the FE loads for further FE analysis. These topics are also covered in the eLearning.
    Hope this helps in creating your model!
  • Vishvam
    Vishvam
    Altair Employee
    Answer ✓
    @Sivaprakash_V
    Sure! If you can share your model (if its shareable), Export the model as an archive and zip it. And mention what specific issue you are facing with creating springs. That will help to provide a better solution.
    For dedicated support you can also create a ticket by mailing to hwsupport@altair.com and one of the MBD experts will connect with you based on your timezone.
  • Vishvam
    Vishvam
    Altair Employee
    Answer ✓
    Sure! You can mail to support, keeping me in CC
    vishvamn@altair.com
Answers
  • Vishvam
    Vishvam
    Altair Employee
  • Sivaprakash_V
    Hi Vishvam,
    Thanks for your reply.
    I hope you saw the video which I shared via Youtube link.
    I have some basic working knowledge in motion solve/view by exploring the E learning tutorials from Altair one few weeks ago. In the tutorial, they use Piton & cylinder assembly and Fourbar linkage Mechanism, I am able to simulate the same mechanism my self by using altair tutorials, but in our application point of view I can't able to simulate it.
    I faced an issues while creating Springs and ball in v grooves present in hammer and its Shaft.
    So I am stuck in that process. Could you help me in this?
    Thanks & Regards,
    Sivaprakash V.
  • Vishvam
    Vishvam
    Altair Employee
    Answer ✓
    @Sivaprakash_V
  • Sivaprakash_V
    Hi ,
    Thanks for your mail. can you share you mail id, we will discuss it via mail.
    Sorry sir, the model is not shareable .
    Thanks & Regards,
    Sivaprakash V.
  • Vishvam
    Vishvam
    Altair Employee
    Answer ✓
    vishvamn@altair.com
  • Sivaprakash_V
    Thanks for sharing the mail id.
    Sure I will send a mail to support and put you in cc.
    Thanks & Regards,
    Sivaprakash v.
Welcome!
Welcome!
