Error #2202 "Error(s) encountered during element check"
Rod
Rod Altair Community Member
edited January 21 in Community Q&A
Hi.
I cannot run a simple model due to this #2202 error. I have turned off CHECKEL already but still it produces this error.
Can anyone tell me what's wrong with my model?
I am not an expert yet so I need help from the experts. I know there are many in this community.
Best Answer
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    Answer ✓
    Hi Rod,
    Please check the below message.
    Element # 17870, element type QUAD4.
    ERROR - Validity limit violation: Vertex Angle = 184.95upper limit = 180.00
    The element with id 17870 is having angle 184 which has crossed the upper limit of 180deg for quad element. Even if you do CHECKEL=NO, it will not work.
    So do a quality check for your model and correct the bad quality elements and rerun.
    Thanks
    Rajashri
Answers
  • Rajashri_Saha
    Rajashri_Saha
    Altair Employee
    Answer ✓
    Hi Rod,
    Thanks
    Rajashri
  • Rod
    Thank you very much.
    I did quality check but I don't know why I missed that. Fixing this one element actually solved the problem.
Welcome!
Welcome!
