S-Frame Display Size Problem
S_Frame_Instructor_1
S_Frame_Instructor_1 Altair Community Member
Hi there! I am using S-Frame, and all the geometry (including joints, members, display legends) is a lot larger than normal. Zooming in and out does not change anything. I am wondering if there is a setting where I can decrease the size of the display? Thank you!
Answers
  • Hello, Edward,
    Thank you for reaching out to us.
    To help you with this issue, please open the folder contained in the next direction on your machine: C:\Users\"yourusername"\AppData\Local\S-FRAME Software
    You may need to activate the hidden folders feature.
    In this folder, locate the “SFRAME.ini” file and delete it.
    Close this window and relaunch S-FRAME, this should help with your elements displayment.
    Let us know how it goes, as we can elaborate on something else if needed.
    Regards,
    Alejandro Lopez
    Altair Support
Welcome!
Welcome!
