🎉Community Raffle - Win $25
Join and Win
Protection Model Simulation Problem
User: "Baris Colak"
Altair Community Member
Dear Experts,
I was trying to get the simulation result of the protected model with some mechanical components. I imported the protected model and the geometry. I added standard configurations and S parameter configuration. If I put 2 or more frequencies (with "List of discrete points") in the configurations, the results are getting on just 0Hz. We can not see other frequency information in the results. The results come true if I put just one frequency in the configurations. Also, in the S parameter configuration, I tried to put 2 frequencies with "List of discrete points" but the result came with just 0Hz. If I put just 1 or with "Linearly spaced discrete points", the result came true. Is there a possibility it is a bug or are we missing some details?
Can you help?
Feko version: 2024.1
Best Regards,
1 - 3 of 31
    Hi Baris,
    Let me test this to see if there is a bug.
    Best regards,
    Torben
    Hi Baris,
    I can reproduce the problem. When list of frequency points is used in the protected model, POSTFEKO is unable to read the frequency values. I will report this to the development team.
    Please excuse the inconvenience!
    Best regards,
    Torben
    User: "Baris Colak"
    OP
    Hi Torben,
    Thank you very much for your prompt response. We look forward to the solution.
    Best Regards,
    Baris
