Particle Explosions
Jake Kim_21578
Jake Kim_21578 Altair Community Member
I am running two simulations
The first simulation has a static friction of 0.8, surface energy of 0.35 mJ and a particle modulus of 2.1GPa. The image below is how it looks like when spread.
The Second simulation has a static friction of 0.8, surface energy of 5.6mJ and a particle modulus of 2.1 GPa. The image below is how it looks when spread.
Why does the bottom image have these particle explosions?
Welcome!
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Jake,
    This is likely related to the EDEM Simulation time-step used. I notice the time-step is relatively low but you have significantly increased the cohesive force included in the simulation, and higher forces typically require lower time-steps to be stable.
    Regards
    Stephen
  • Jake Kim_21578
    By the cohesive forces you mean the surface energy correct?
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Jake, that's correct.
Welcome!
Welcome!
