How can I remove this error in wire meshing? [FEKO 2023.1 Version]
sswh2
sswh2 Altair Community Member
Hi , My probe radius is 5mm in my model, I tried using Fine /standard meshing option in my model, but for both cases, there is the same error msg "The ratio of probe radius to length is very large" . My model is attached here. Kindly check the model and
help me to fix this error message in my simulation. Thanks in advance!
Best Answer
  • Jaehoon
    Jaehoon
    Altair Employee
    Answer ✓
    If you'd like to consider the feeder wire's radius, you need to replace the wire with a 3D geometry (cylinder).
    Please refer to the following steps.
    1. Draw a cylinder. ← after deleting the wire feeder.
    2. Region medium → Free space
    3. Split the cylinder and union.
    4. Apply the edge port. → Voltage source.
    Best regards,
    Jaehoon
Answers
  • Jaehoon
    Jaehoon
    Altair Employee
    Hello,
    Feko's wire segment mesh is based on the thin wire approximation. Therefore, the wire segment's radius should be smaller than the segment's length (Maybe 5~10 times smaller).
    Please change the wire segment radius (5 → 0.001) in Modify mesh setting as shown below.
    Best regards,
    Jaehoon
  • sswh2
    edited December 21
    @Jaehoon sir, my requirement is my probe radius should be 5/2( 2.5) mm then how can I fix this issue? I can not change it thats the requirement, kindly tell me how can I fix this error then wthout creating proper cylindrical coax probe?
  • sswh2
    @Torben Voigt sir can you help fixing this error? my probe radius should be 2.5mm
  • sswh2
    @Jaehoon sir I can't change the radius thats the requirement then how can I fix the error?
  • Jaehoon
    Jaehoon
    Altair Employee
    Answer ✓
    Best regards,
    Jaehoon
  • sswh2
    @Jaehoon sir thanks, let me see how this cylinder effects my s11 .
